Help me decide
17 replies to this topic
Poll: decisions (5 member(s) have cast votes)
Which card of graphics
  1. GeForce GTX 1060 3gb for $200 (1 votes [20.00%])
    Percentage of vote: 20.00%
  2. GeForce GTX 1060 6gb for $280 (4 votes [80.00%])
    Percentage of vote: 80.00%
  3. GeForce GTX 960 2gb for $180 (0 votes [0.00%])
    Percentage of vote: 0.00%
  4. Current Radeon HD 7870 2gb (0 votes [0.00%])
Vote Guests cannot vote
DarkFox
DarkFox
  • 2,378 posts
  • CN Nation ID:215271
  • Souls Baptized:7
Currently my computer is pretty stacked, I have a lower high end Mobo, plenty of ram and an 8 core processor but my computer has been having framerate issues as of late and I cannot do utilize my set up properly. I have come to the conclusion that it is probably my GPU that is lacking. I have a Radeon HD 7870, so if you were in my shoes and would like to be able to play on max settings for games and to enjoy the nice graphics what would you upgrade to? Options in the pull
DarkFox, Since joining IRON you have been a great asset in our Military. You exemplify the IRON Values in support of IRON. Your hard work and dedication is not unnoticed.
DarkFox has been baptized in Fire and Blood and emerged as IRON!
cbrndragon209
cbrndragon209
  • 354 posts
  • CN Nation ID:591626
  • Souls Baptized:39,768
Not sure but try this website, my friend use it a lot.
http://www.neoseeker.com/Hardware/
cbrndragon209 - Arch Chancellor of Eden Prime
Proudly took 4 Nuke's for IRON
Wars fought: 6
First Declared war - 6/29/16 (CeNgKaOe26 of SaliP)
First nation send into Anarchy - 7/1/16 (CeNgKaOe26 of SaliP)
First nuke taken: 7/2/16 (CeNgKaOe26 of SaliP)
"Ferro Credimus"
"Ad Victoriam" (To Victory)
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
I've checked the speeds and such, this is more of what should I do money wise. I've narrowed it down to 3 cards for possible upgrades, but at the same token I don't even know if I should upgrade my computer
Blade 619
Blade 619
    Master of Nukes
  • IRON President
  • 7,598 posts
  • CN Nation ID:040973
  • Souls Baptized:7,122,755
  • Discord ID:Blade
What are you having FPS issues with? If it's 4k gaming then my answer is different from if it's just general 1080p?
Blade 619 you have been baptized in Fire and Blood and emerged as IRON!
  I will remember this, Blade, and I will be forever grateful... oh hell words fail me!  ( @ )( @ )
Revenge is best served cold, tasting of vanilla yoghurt with vanilla and chocolate balls.
Leave it to Blade to step in and say the most completely true post in this thread. You make my day Sir.
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
Mainly frame rate with Eve, and a few others. I also have had issues watching netflix on one monitor while playing a game on another, and then pretending to work in the background of all that.
Mazuurek
Mazuurek
  • 504 posts
  • CN Nation ID:587499
  • Souls Baptized:121,338
  • Discord ID:Mazuurek
What resolution are you playing at? How many monitors?
around 9 nukes taken
SeaBeeGipson
SeaBeeGipson
    Retired
  • 2,610 posts
  • CN Nation ID:552359
  • Souls Baptized:Seven
Before you go about replacing and buying stuff, have you tried Razor? It helps to eliminate back programs and free up some space to push a decent amount of fps into your gameplay. I was getting 30-60fps depending on the game and with Razor alot, I can hit the 120s (isn't useful though as my monitor is optimized at 60fps, so anything over is kind of pointless.)
Formerly King Hitler of Deutsche.
IRON Diplomacy: Being Nice to Alliances we're about to roll since 2007.
With Great Power, Comes Great Responsibility and headaches.
Click to Add Me on FaceBook
Message Me to Apply for Diplomat Corps!
Ultimate Guide to CyberNations
Model Nations
Join Discord Here: Click ME!!
Get your Discord Member Mask Here!
Hit me up on RuneScape like it is 2008
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
two monitors at 1920x1080
 Any background stuff should be dealt by the CPU, which is excessive so I doubt that is the issue.
Mazuurek
Mazuurek
  • 504 posts
The 3gb 1060 should be good enough if you're not planning to get higher resolution monitors.
DeathMerchant
DeathMerchant
  • Military - Radar Leadership
  • 6,831 posts
  • CN Nation ID:156811
Would you mind giving us a list of all your parts? What clock speed is your CPU set at? And what OS you are using? And lastly, disable a bunch of unused background programs, that will give you some temporary relief until you upgrade.
If you plan on using two monitors then you will want the extra VRAM in the GTX 1060 6gb.
The idea of war is not to die for your country, it's to make the enemy die for his.
Former Member of the VOC
IRON STATS Wars Fought: 13 POWs Taken: 2 Nations ZIed: 2 Aid Given: $341 Million
Recruits: 7 Alliances Fought: LSF, Sparta, VE, Umbrella, DBDC, STA
Alliance Seniority: 2,595 Days Soldier Casualties: 867,426 Att + 2,123,326 Def = 2,990,752
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
windows 10, 16gb of ram, AMD Fx 8350 eight core processor
If I am upgrading I want to future proof a bit. Games already starting to have 3gb in the recommended specs
DeathMerchant
DeathMerchant
  • 6,831 posts
That AMD CPU will likely start causing bottlenecks even if you buy a powerful card. You won't notice it in games that aren't very hardware intensive. But if the game is CPU intensive you will get some erratic frame rate drops. You could always buy a new card and see how it goes. And then whenever you are ready to upgrade the rest of the PC, all you would have to be is a new CPU + MOBO, and possibly RAM depending if your old one is compatible with the new MOBO.
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
The processor is better than any game's recommended on even the highest settings and is a high end processor; Why would you say that it would cause a slow down?
DeathMerchant
DeathMerchant
  • 6,831 posts
My mistake, first time I saw your post I thought it said FX 8320. Which when paired with a GTX 1070 is getting bottlenecks in games like Arma 3, GTA V, or other early access games.
FX 8350 has a better clock speed and better potential overclocking. You will be fine using that CPU for quite some time and shouldn't run into any issues.
Hung Wang
Hung Wang
    Baptized
  • 751 posts
  • CN Nation ID:583597
  • Souls Baptized:
What is the processor you have? I'm just a little curious.
"-17.60 - Your population absolutely hates you."
Life is the difference between jumping out of a third story window and jumping off a penthouse suite.
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
I posted above, but here it is again AMD Fx 8350 eight core processor
Also thank you for the discussion guys I ordered the 6gb 1060. I figure the cost will be acceptable if all the reviews for the card are correct.
Hung Wang
Hung Wang
    Baptized
  • 751 posts
  • Souls Baptized:
I actually can't even see it?
DarkFox
DarkFox
  • 2,378 posts
  • Souls Baptized:7
http://ironcentral.org/community/topic/58227-help-me-decide/?p=881773
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
