Help me build my PC
52 replies to this topic
#41
Samus
Samus
    The Convict
  • Samus Mask
  • 14,701 posts
  • CN Nation ID:254470
  • My Aid Data:254470
  • Souls Baptized:2,311,441
Thanks for advice guys.
Just to reiterate, some people have advised I return the cooler I bought and just use the cooler that comes with the CPU instead as i'm primarily only streaming on this PC.
What do you think?
Root Admin
Ex-Kilo CO, Ex-Bounty Director, Ex-Mentor, Ex-Admissions Admin Ex-Deputy Headmaster of Academy, Ex-Recruitment Staff, Ex-SWAG Personell, Ex-Academy Staff, Ex-Trade Post Director, Ex-Deputy Trade Post Director, Ex- Foxtrot Master Sergeant, Ex-Award Panel Deputy Director, Ex-Award Panel Staff, Ex-Trade Post Staff, Ex- Delta Executive Officer, Ex-Express Delivery
00:48 Fernando[IRON] � I will refer to you as Supreme Overlord Guru Samus
Only I have the baptismal power.
Samus because of your dedicated service to IRON; your high casualty count and aid given your fellow IRONers. I hear by baptize ye in Fire and blood. You rise as IRON!
You may now wear proudly in your Sig "I have been Baptized in Fire and Blood and emerged as IRON."
18:28 %FinsterBaby[IRON] • I'm only afraid of Master Samus.
18:28 %FinsterBaby[IRON] • All powerful root admin
18:29 @onbekende • wussie
18:29 %FinsterBaby[IRON] • he can make you disappear. I've seen it
MVP(Mod’s Choice)= Master Samus; I think Master Samus played amazingly for a guy who claims it was his second only mafia game. He never led the town on him and that’s why he deserves this award. He was impressive in manipulating the town that led to the ultimate mafia victory.
Player of Mafia; Master Samus/emudevelopment (shared); I think both were instrumental in the town’s defeat. Both were manipulative and deceptive. They clearly came out as pro-town and looked like de-facto town leaders. They led the lynch wagon w/o anyone uncovering their true motives.
Samus, you should be proud that you've helped make an environment where people feel safe enough to share their experiences.
Blade 619
Blade 619
    Master of Nukes
  • 7,601 posts
  • CN Nation ID:040973
  • Souls Baptized:7,122,755
  • Discord ID:Blade
Depends on how good the airflow is in your case. But honestly watercooling is significantly better and much easier to just do it how you want it to start with than change coolers down the line.
Shadow: https://shadow.tech/gben
Blade 619 you have been baptized in Fire and Blood and emerged as IRON!
  I will remember this, Blade, and I will be forever grateful... oh hell words fail me!  ( @ )( @ )
Revenge is best served cold, tasting of vanilla yoghurt with vanilla and chocolate balls.
Leave it to Blade to step in and say the most completely true post in this thread. You make my day Sir.
Rhizoctonia
Rhizoctonia
    Retired
  • 7,700 posts
  • CN Nation ID:314185
  • Souls Baptized:7,436,130
What do you think?
I'd have to see what cooler you got.  I think most are saying if you didn't want to spend the money, try the cooler that comes with it and see how your temps get.  Water cooling is likely more efficient, but some have restraint of having water with all electronics inside if something would happen like a leak.   I believe I have the same/similar case as you, so I can show you how I've set mine up.  I think it's pretty good wire management, but no expert on it.  You just need to mainly figure out where things plug into your MB, and make sure you run cord through the openings in back that are closest.
Also, congrats on your first build.  But make sure you don't rush through building it, and take it step by step.  Mine took me awhile the first build I did, with a lot of reading tutorials while doing it, and videos.
Former Government Of The East India Company(VOC)
joe44
joe44
    IRON's High Priest
  • 2,373 posts
  • CN Nation ID:568614
  • Souls Baptized:11,474,821
https://m.twitch.tv/directory/game/PC Building Simulator  ;)
Edited by joe44, 12 February 2019 - 10:25 PM.
Rand0m her0
Rand0m her0
  • 3,259 posts
  • CN Nation ID:610507
Even for gaming, the stock cooler is probably fine. I think i mentioned that a few pages back? They're rarely *good* coolers, but they do work well enough. Worst case of using it is that your CPU starts to throttle itself to manage heat. It's not going to melt itself or anything
You *might* have an issue with fan noise. AMD coolers in my experience have tended to be quiet loud, although that was some years back. If that's still the case it might be an issue for streaming, unless you're going for the  "games next to a jet engine" ambiance.
If you want, leave the cooler you bought in the box, stick the stock cooler in, and run the system though a bench mark. See how hot the CPU gets and how loud the fan gets, see if anything starts to throttle. Fart around with it for a few days.  If it's not an issue, return the aftermarket cooler. If it is an issue...well it'll take you like 10 minutes to swap the part out. Just make sure to clean off and replace the thermal paste when you do.
Watercooling is really nice (and so damn quiet!) but so very not needed unless your overclocking.
5 points!
134623
DeathMerchant
DeathMerchant
  • Military - Radar Leadership
  • 6,854 posts
  • CN Nation ID:156811
Since you're using this PC mainly for streaming, you could give the Stock Cooler a try and it will probably give you decent Temps. Not as good as the aftermarket, but unless you are running some software that is CPU intensive, you shouldn't have problems.
The idea of war is not to die for your country, it's to make the enemy die for his.
Former Member of the VOC
IRON STATS Wars Fought: 13 POWs Taken: 2 Nations ZIed: 2 Aid Given: $341 Million
Recruits: 7 Alliances Fought: LSF, Sparta, VE, Umbrella, DBDC, STA
Alliance Seniority: 2,595 Days Soldier Casualties: 867,426 Att + 2,123,326 Def = 2,990,752
joe44
joe44
    IRON's High Priest
  • 2,373 posts
hmm...who care nowadays ab buggy games?
Rafay
Rafay
  • 4,488 posts
  • CN Nation ID:607118
I also need help for laptop purchase.
Is a processor with 1.6 GHz speed with Turbo 3.4 better than a 2.4 ghz processor?
Can you recommend any laptops models with the following specs.
8 GB ram
1 tb hdd
6-8 mb cache
2.4 ghz or more processor.
I dont need for gaming. Just for surfing, ms office and watching movies.
Rafay
Rafay
  • 4,488 posts
Oh come on guys.
Samus
Samus
    The Convict
  • Samus Mask
  • 14,701 posts
Oh come on guys.
where have you searched?
Root Admin
DeathMerchant
DeathMerchant
  • 6,854 posts
8 GB ram
1 tb hdd
6-8 mb cache
Clock speed isn't the sole factor in determing processor power and efficiency. To theorize, let's say a 8 Core AMD CPU has a clock speed of 3.2 GHz, whereas a 4 Core Intel CPU has a clock speed of 3.0ghz. You would think that by looking at raw numbers the AMD CPU would win, but in reality the Intel processor will be the better choice as the Intel architecture is superior to AMD CPUs and will offer better performance (but at a higher price).
If the Turbo is Factory Overclocked that is always Overclocked, then it might be worth it. Just remember that Laptops can get pretty hot as is, so an Overclocked Processor on a full load will really heat up. Take extra steps to insure it remains cool.
The specs you listed will be adequate for what you planned to do with it. No need for a high end processor if you only plan to have one or 2 low intensive tasks running at a single time.
Rafay
Rafay
  • 4,488 posts
Yes its intel core i5 8th gen processor.
DeathMerchant
DeathMerchant
  • 6,854 posts
It should suit your needs well then.
