ATTN: Hardware Geeks, Help Me Out
7 replies to this topic
ccabal86
ccabal86
  • 12,373 posts
  • CN Nation ID:362483
  • Souls Baptized:5,083,976
What do you think of this rig:
MoBo: Gigabyte B450M DS3H
Processor: AMD Ryzen 5 3600X
Cooler: COOLERMASTER MasterLiquid ML240L RGB
Memory: 24 GB - HyperX 3200 MHz DDR4
GPU: GeForce GTX 1660 SUPER OC 6G
Power unit: Seasonic Focus SGX-450
SSD: SA400S37/240G
HDD: 2TB HDD WD Blue WD20EZRZ
Case: ZALMAN i3 series Edge
I can get the whole chebang barely used for just under $1k. I fully trust that the seller is honest in the deal.
So, what do you say? Should I go for it?
Blade 619
Blade 619
    Master of Nukes
  • IRON President
  • 7,598 posts
  • CN Nation ID:040973
  • Souls Baptized:7,122,755
  • Discord ID:Blade
The buy new price is about 1k too.
You'll need to upgrade the power supply when you upgrade anything on it. If you need a rig and don't want to DIY, it's not a bad buy.
Blade 619 you have been baptized in Fire and Blood and emerged as IRON!
  I will remember this, Blade, and I will be forever grateful... oh hell words fail me!  ( @ )( @ )
Revenge is best served cold, tasting of vanilla yoghurt with vanilla and chocolate balls.
Leave it to Blade to step in and say the most completely true post in this thread. You make my day Sir.
DeathMerchant
DeathMerchant
  • Military - Radar Leadership
  • 6,825 posts
  • CN Nation ID:156811
^ What Blade said. Should be good for 1080p gaming. You will want a better card if your going to do 2K or 4K.
24GB of RAM is kind of weird, is it 4 sticks of 6GB? Usually RAM is either 16GB or 32GB.
The idea of war is not to die for your country, it's to make the enemy die for his.
Former Member of the VOC
IRON STATS Wars Fought: 13 POWs Taken: 2 Nations ZIed: 2 Aid Given: $341 Million
Recruits: 7 Alliances Fought: LSF, Sparta, VE, Umbrella, DBDC, STA
Alliance Seniority: 2,595 Days Soldier Casualties: 867,426 Att + 2,123,326 Def = 2,990,752
dsfrr1
dsfrr1
  • 6,216 posts
  • CN Nation ID:614863
  • Souls Baptized:1,492,420
^ Get some info on the RAMs like how many sticks and if they are dual channel (they should be dual channel)
ccabal86
ccabal86
  • 12,373 posts
Thanks for the input guys. It seems like a decent machine, but I probably won't buy because I'd like to transition to 4k gaming.
Blade 619
Blade 619
    Master of Nukes
  • IRON President
  • 7,598 posts
  • Discord ID:Blade
Yep... that's the $2k club right there.
ccabal86
ccabal86
  • 12,373 posts
Well, it was going to happen eventually :unsure:
Kaziocore
Kaziocore
  • 9,074 posts
  • CN Nation ID:320094
  • Souls Baptized:Over 9000
You probably need more than $2k for 4k if you take into account the monitor
I'd personally wait 1-2 generations of video card before moving to 4k.
Mafia fail statistics: 13 Wins (11T/1M/1O), 7 Loses (6T/1O), 4 Draws/Abandoned
Code Geass Mafia is currently looking for players. Come play with us!
